跳转到主内容
Nikon Coolpix S6300 Display Replacement
你所需要的
  1. Nikon Coolpix S6300 Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Display Replacement: 步骤 2 中的图像 1,1
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Display Replacement, Buttons: 步骤 3 中的图像 1,3 Nikon Coolpix S6300 Display Replacement, Buttons: 步骤 3 中的图像 2,3 Nikon Coolpix S6300 Display Replacement, Buttons: 步骤 3 中的图像 3,3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Display Replacement: 步骤 4 中的图像 1,3 Nikon Coolpix S6300 Display Replacement: 步骤 4 中的图像 2,3 Nikon Coolpix S6300 Display Replacement: 步骤 4 中的图像 3,3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Display Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Display Replacement: 步骤 6 中的图像 1,1
    • Remove the two clasp using a plastic spudger
    • Be careful when removing the clasp to prevent ripping of the clasp
  7. Nikon Coolpix S6300 Display Replacement: 步骤 7 中的图像 1,1
    • You may now remove the internal panel of the buttons
  8. Nikon Coolpix S6300 Display Replacement, Display: 步骤 8 中的图像 1,1
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
结论
Hung
于09/01/15注册
383 声望
创作了2篇指南
团队
USF Tampa, Team 1-2, Remmell Fall 2015 USF Tampa, Team 1-2, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G2
5 名成员
创作了10篇指南
2条评论
Step 8 could have better pictures and explanation of the clasp...or picture of the clasp. I think it was some white tape looking stuff that I did break. Looking for better instructions elsewhere. I think I just made the situation worse
Lisa F - 回复
I have this problem with my coolpix (see images and video):
https://i.postimg.cc/pXk2L4QB/20190201-1...
https://i.postimg.cc/d3wYqjLX/20190201-1...
https://i.postimg.cc/RCLmgyYz/20190201-1...
https://drive.google.com/file/d/1sDr8fPD...
Screen has a posterized effect.
I already replaced the screen with a new one, but the problem remains..
Any idea what is faulty, and how can I fix it?
Geo Nik - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 33
总计 1,477
