跳转到主内容
Nikon Coolpix S6300 Buttons Replacement
你所需要的
  1. Nikon Coolpix S6300 Buttons Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Buttons Replacement: 步骤 2 中的图像 1,1
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Buttons Replacement, Buttons: 步骤 3 中的图像 1,3 Nikon Coolpix S6300 Buttons Replacement, Buttons: 步骤 3 中的图像 2,3 Nikon Coolpix S6300 Buttons Replacement, Buttons: 步骤 3 中的图像 3,3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Buttons Replacement: 步骤 4 中的图像 1,3 Nikon Coolpix S6300 Buttons Replacement: 步骤 4 中的图像 2,3 Nikon Coolpix S6300 Buttons Replacement: 步骤 4 中的图像 3,3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Buttons Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the PH 2 mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Buttons Replacement: 步骤 6 中的图像 1,1
    • Disconnect the connectors using a plastic spudger.
    • Be careful when removing the cables to prevent damaging the connectors.
  7. Nikon Coolpix S6300 Buttons Replacement: 步骤 7 中的图像 1,1
    • You may now remove the internal panel of the buttons.
结论
另外一个人完成了本指南。
Michael Lynch
于08/31/15注册
396 声望
创作了3篇指南
团队
USF Tampa, Team 1-2, Remmell Fall 2015 USF Tampa, Team 1-2, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G2
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 827
