当前版本的文档还未经巡查,您可以查看最新的已查核版本。
The battery compartment is located on the bottom of the camera.
Place your thumb on the battery door.
Slide the door away from the camera in the direction the arrow points to.
Locate a small, rectangular flap above the battery cover door.
Push the small, rectangular flap back through the hole.
Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
Make sure to hold the camera down when removing the front cover.
在这个步骤中使用的工具:
购买
Using tweezers, gently slide the shutter button out.
Be very gentle because you can damage the piece.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
