跳转到主内容
Nikon Coolpix S630 LCD Screen Replacement
你所需要的
  1. Nikon Coolpix S630 LCD Screen Replacement, Battery Compartment: 步骤 1 中的图像 1,1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 LCD Screen Replacement, Battery: 步骤 2 中的图像 1,1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 LCD Screen Replacement, Memory Card: 步骤 3 中的图像 1,1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 LCD Screen Replacement, Back Cover Removal: 步骤 4 中的图像 1,3 Nikon Coolpix S630 LCD Screen Replacement, Back Cover Removal: 步骤 4 中的图像 2,3 Nikon Coolpix S630 LCD Screen Replacement, Back Cover Removal: 步骤 4 中的图像 3,3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Nikon Coolpix S630 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Nikon Coolpix S630 LCD Screen Replacement, Detaching Ribbon: 步骤 6 中的图像 1,2 Nikon Coolpix S630 LCD Screen Replacement, Detaching Ribbon: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  7. Nikon Coolpix S630 LCD Screen Replacement, LCD Screen Removal: 步骤 7 中的图像 1,3 Nikon Coolpix S630 LCD Screen Replacement, LCD Screen Removal: 步骤 7 中的图像 2,3 Nikon Coolpix S630 LCD Screen Replacement, LCD Screen Removal: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Lift LCD screen carefully from the metal casing
    • Be cautious when lifting screen as it is still connected to the logic board by two ribbons
    • Lift the two tabs for both ribbons with a plastic case opener like in the previous step
    • Pull out ribbons gently from the logic board with tweezers to disconnect screen
  8. Nikon Coolpix S630 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Disconnect the LCD screen from the logic board!
结论
另外一个人完成了本指南。
Anna Katrina
于04/18/13注册
28 声望
创作了2篇指南
团队
Cal Poly, Team 8-56, Johann Spring 2013 Cal Poly, Team 8-56, Johann Spring 2013 的会员
CPSU-JOHANN-S13S8G56
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 29
总计 1,235
