当前版本的文档还未经巡查,您可以查看最新的已查核版本。
The battery compartment is located on the bottom of the camera.
Place your thumb on the battery door.
Slide the door away from the camera in the direction the arrow points to.
Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
Gently pull the ribbon from the logic board with tweezers.
With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
Locate a small, rectangular flap above the battery cover door.
Push the small, rectangular flap back through the hole.
Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
Make sure to hold the camera down when removing the front cover.
Locate the small rod that is securing the door in place
Using a tweezers, grab the rod and slowly pull the rod out
Note: Be careful as you try to pull the rod out because the spring may pop out
Replace battery cover door.
Note: To reinstall a new battery cover door, make sure you have these parts: spring, rod, and the battery cover door.
Place battery cover door back into place with spring between the insertion holes.
Using a tweezers, gently slide the rod through the insertion holes and through the spring.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
