跳转到主内容
Nikon Coolpix S5300 LCD Display Screen Replacement
你所需要的
  1. Nikon Coolpix S5300 LCD Display Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the camera upside down and locate the battery compartment.
    • Slide the compartment open following the direction of the arrow.
  2. Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 2 中的图像 1,1
    • Press the orange release button to release and remove the battery.
    • Replace or insert battery in it's respective terminals
  3. Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: 步骤 3 中的图像 1,3 Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: 步骤 3 中的图像 2,3 Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: 步骤 3 中的图像 3,3
    • Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
    • Using the same screwdriver, remove the 2 screws on the side of the camera.
    • Remove the 2 screws from the other side of the camera.
    • One of the screws is under the I/O port cover.
  4. Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 4 中的图像 1,3 Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 4 中的图像 2,3 Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to carefully separate the cover from the camera.
    • Work the plastic opening tool around all the edges of the front plate.
    • Pull the purple plastic cover off gently from the screen.
  5. Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 5 中的图像 3,3
    • Turn the camera over so the LCD screen is facing you.
    • Carefully remove the front shell by gently prying around the corners with the plastic opening tool until it releases.
  6. Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 6 中的图像 2,2
    • Be careful to keep track of little pieces of the outside casing.
  7. Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 7 中的图像 2,2
    • Carefully remove the top button casing by pulling it away from main camera.
  8. Nikon Coolpix S5300 LCD Display Screen Replacement, Button Panel: 步骤 8 中的图像 1,1
    • Remove the 2 screws on the silver plate
    • Gently lift the screen and silver plate away from the internal components.
    • Do not separate the plate and screen from the camera
  9. Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 9 中的图像 1,2 Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 9 中的图像 2,2
    • Carefully move the button panel away from the silver plate.
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap.
    • Safely pull the ribbon cable out and then remove the button panel.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
  10. Nikon Coolpix S5300 LCD Display Screen Replacement, LCD Display Screen: 步骤 10 中的图像 1,2 Nikon Coolpix S5300 LCD Display Screen Replacement, LCD Display Screen: 步骤 10 中的图像 2,2
    • Carefully remove the screen away from the silver plate.
    • Carefully fold the screen over exposing the latch for the ribbon cable.
  11. Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 11 中的图像 1,3 Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 11 中的图像 2,3 Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 11 中的图像 3,3
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  12. Nikon Coolpix S5300 LCD Display Screen Replacement: 步骤 12 中的图像 1,1
    • Once the ribbon cable is disconnected, remove the LCD screen.
结论
Waleed Chakir
于03/04/16注册
301 声望
创作了3篇指南
团队
UMass Dartmouth, Team 6-1, Bhusal Spring 2016 UMass Dartmouth, Team 6-1, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S6G1
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 31
总计 1,719
