跳转到主内容
Nikon Coolpix S5200 LCD Screen Replacement
你所需要的
  1. Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • There are four 0.1 mm screws holding the front and back of the camera together all along the outside of the camera
    • There should be four screws
  2. Nikon Coolpix S5200 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips Head screw driver head to remove the four 0.1 mm screws surrounding the outer edges of the camera
  3. Nikon Coolpix S5200 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Pull the plastic back cover off of and away from the LCD screen
  4. Nikon Coolpix S5200 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the LCD screen from the silver plate that once held it in place by pulling it away from the internal components
  5. Nikon Coolpix S5200 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the six designated screws sized 0.1 mm from the metal plate using a Phillip's Head screwdriver in size PH00.
  6. Nikon Coolpix S5200 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Lift the metal plate away from the internal components of the camera
  7. Nikon Coolpix S5200 LCD Screen Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix S5200 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Carefully remove the LCD screen by pulling it away from the camera. Repeat these steps in reverse order to install the new LCD screen.
结论
另外一个人完成了本指南。
1指南评论
Shouldn't the replacement LCD screen be considered a part? It is in fact very difficult to replace it without having the part to replace.
joshronsen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 1,491
