跳转到主内容
Nikon Coolpix S51c Back Cover Replacement
你所需要的
  1. Nikon Coolpix S51c Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Nikon Coolpix S51c Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
  2. Nikon Coolpix S51c Back Cover Replacement: 步骤 2 中的图像 1,1
    • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using the Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Back Cover Replacement: 步骤 3 中的图像 1,1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Back Cover Replacement: 步骤 4 中的图像 1,1
    • Lift the back cover.
    • Be careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Back Cover Replacement: 步骤 5 中的图像 1,1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
    • Carefully remove the back cover.
结论
另外一个人完成了本指南。
Ryan
于04/12/11注册
155 声望
创作了6篇指南
团队
Cal Poly, Team 18-24, Garner Spring 2011 Cal Poly, Team 18-24, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G24
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,350
