跳转到主内容
Nikon Coolpix S4100 LCD Screen Replacement
你所需要的
  1. Nikon Coolpix S4100 LCD Screen Replacement, External Casing: 步骤 1 中的图像 1,3 Nikon Coolpix S4100 LCD Screen Replacement, External Casing: 步骤 1 中的图像 2,3 Nikon Coolpix S4100 LCD Screen Replacement, External Casing: 步骤 1 中的图像 3,3
    • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
    • There are 2 on each side, and 4 on the bottom.
  2. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the black casing on the back of the camera that runs around the LCD screen.
  3. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
  4. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 4 中的图像 1,3 Nikon Coolpix S4100 LCD Screen Replacement: 步骤 4 中的图像 2,3 Nikon Coolpix S4100 LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Pry off the front shell casing.
    • If you find this difficult, use a prying tool to help gently remove the casing.
  5. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
  6. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix S4100 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
  7. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 7 中的图像 1,3 Nikon Coolpix S4100 LCD Screen Replacement: 步骤 7 中的图像 2,3 Nikon Coolpix S4100 LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Remove the lanyard mount and accompanying side shell casing off of the camera.
  8. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
  9. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
  10. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Remove the remaining side shell casing.
  11. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Remove the top shell casing.
  12. Nikon Coolpix S4100 LCD Screen Replacement, Functional Button Plate: 步骤 12 中的图像 1,1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
  13. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    • Using precision tweezers, remove the ribbon cable that runs from the functional buttons plate to the under side of the motherboard.
  14. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 14 中的图像 1,1
    • Using precision tweezers, lift up the bottom of the functional buttons plate and remove the metal plate.
  15. Nikon Coolpix S4100 LCD Screen Replacement, LCD Screen: 步骤 15 中的图像 1,2 Nikon Coolpix S4100 LCD Screen Replacement, LCD Screen: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    • Using precision tweezers, gently remove the ribbon cable running from LCD to the bottom side of the motherboard.
  16. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 16 中的图像 1,2 Nikon Coolpix S4100 LCD Screen Replacement: 步骤 16 中的图像 2,2
    • Using precision tweezers, gently lift up on the black strip of the ZIF Connector securing the cable from the LCD to the motherboard.
    • Then, gently remove the wire by pulling the base of the ribbon cable towards the LCD screen.
    • Do not poke or destroy the cable itself. Be careful to only grab the black fold in the tweezers.
    • The black strip will fold back to reveal the cable, but remain attached to the motherboard.
  17. Nikon Coolpix S4100 LCD Screen Replacement: 步骤 17 中的图像 1,2 Nikon Coolpix S4100 LCD Screen Replacement: 步骤 17 中的图像 2,2
    • Remove the LCD screen from the metal mount.
结论
Matthew Willis
于09/22/15注册
598 声望
创作了4篇指南
团队
Baylor, Team 4-2, Williams Fall 2015 Baylor, Team 4-2, Williams Fall 2015 的会员
BU-WILLIAMS-F15S4G2
4 名成员
创作了8篇指南
一条评论
Quick question would this be similar to replacing the screen for the Nikon Coolpix S4300? I couldn't find anything to fix that specific camera.
Malakai Ashenafi - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 25
总计 1,017
