跳转到主内容
Nikon Coolpix S3100 Camera Lens Replacement
你所需要的
  1. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 1,3 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 2,3 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 3,3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Lens Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix S3100 Camera Lens Replacement: 步骤 2 中的图像 2,2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Lens Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix S3100 Camera Lens Replacement: 步骤 3 中的图像 2,2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Lens Replacement, LCD Screen: 步骤 4 中的图像 1,1
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera Lens Replacement: 步骤 5 中的图像 1,1
    • Gently pull the orange board to the right.
  6. Nikon Coolpix S3100 Camera Lens Replacement: 步骤 6 中的图像 1,1
    • Lift screen up holding both corners.
  7. Nikon Coolpix S3100 Camera Lens Replacement: 步骤 7 中的图像 1,1
    • Gently pull to the left to release from ZIF connector.
  8. Nikon Coolpix S3100 Camera Lens Replacement, Lens: 步骤 8 中的图像 1,1
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
  9. Nikon Coolpix S3100 Camera Lens Replacement: 步骤 9 中的图像 1,1
    • Gently pull the shutter up.
  10. Nikon Coolpix S3100 Camera Lens Replacement: 步骤 10 中的图像 1,1
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  11. Nikon Coolpix S3100 Camera Lens Replacement: 步骤 11 中的图像 1,1
    • Use a nylon or metal spudger to release the lens.
  12. Nikon Coolpix S3100 Camera Lens Replacement: 步骤 12 中的图像 1,1
    • Repeat step 4 to the opposite side of the lens.
  13. Nikon Coolpix S3100 Camera Lens Replacement: 步骤 13 中的图像 1,1
    • The lens is now separated.
结论
11等其他人完成本指南。
Jorge
于03/11/15注册
1,170 声望
创作了7篇指南
团队
Colorado Springs, Team 2-4, Panko Spring 2015 Colorado Springs, Team 2-4, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G4
2 名成员
创作了13篇指南
6条评论
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
William Dawson - 回复
Nikon coolpix s3100 lens mocking place help my
Nanji Buchiya - 回复
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
Bimolthou Thuodam - 回复
I have same issue it shutter half opens and doesnt open correctly
shailendra - 回复
my LCD screen is stuck on white after after i did this :(
andrew welles - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 58
总计 4,689
