跳转到主内容
Nikon Coolpix S3100 Camera Holder Replacement
你所需要的
  1. Nikon Coolpix S3100 Camera Holder Replacement, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 1,3 Nikon Coolpix S3100 Camera Holder Replacement, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 2,3 Nikon Coolpix S3100 Camera Holder Replacement, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 3,3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Holder Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix S3100 Camera Holder Replacement: 步骤 2 中的图像 2,2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Holder Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix S3100 Camera Holder Replacement: 步骤 3 中的图像 2,2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Holder Replacement, Holder: 步骤 4 中的图像 1,1
    • Remove 2-2.90mm using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera Holder Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
结论
Jorge
于03/11/15注册
1,170 声望
创作了7篇指南
团队
Colorado Springs, Team 2-4, Panko Spring 2015 Colorado Springs, Team 2-4, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G4
2 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 407
