跳转到主内容
Nikon Coolpix S3100 Camera Disassembly
你所需要的
  1. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 1,3 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 2,3 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 disassembly: 步骤 1 中的图像 3,3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Disassembly: 步骤 2 中的图像 1,2 Nikon Coolpix S3100 Camera Disassembly: 步骤 2 中的图像 2,2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Disassembly: 步骤 3 中的图像 1,2 Nikon Coolpix S3100 Camera Disassembly: 步骤 3 中的图像 2,2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 Camera Disassembly: 步骤 4 中的图像 1,2 Nikon Coolpix S3100 Camera Disassembly, Nikon Coolpix S3100 Camera Disassembly: 步骤 4 中的图像 2,2
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
    • Gently pull the orange board to the right. (picture 2)
  5. Nikon Coolpix S3100 Camera Disassembly: 步骤 5 中的图像 1,3 Nikon Coolpix S3100 Camera Disassembly: 步骤 5 中的图像 2,3 Nikon Coolpix S3100 Camera Disassembly: 步骤 5 中的图像 3,3
    • Lift screen up holding the corners.
    • Gently pull to the left to release from ZIF connector. (picture 2)
    • Gently pull the orange board to the right. (picture 3)
  6. Nikon Coolpix S3100 Camera Disassembly: 步骤 6 中的图像 1,2 Nikon Coolpix S3100 Camera Disassembly: 步骤 6 中的图像 2,2
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
    • Gently pull the shutter up. (picture 2)
  7. Nikon Coolpix S3100 Camera Disassembly: 步骤 7 中的图像 1,2 Nikon Coolpix S3100 Camera Disassembly: 步骤 7 中的图像 2,2
    • Lens is now separated from body.
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  8. Nikon Coolpix S3100 Camera Disassembly: 步骤 8 中的图像 1,3 Nikon Coolpix S3100 Camera Disassembly: 步骤 8 中的图像 2,3 Nikon Coolpix S3100 Camera Disassembly: 步骤 8 中的图像 3,3
    • Use a nylon or metal spudger to release the lens.
    • Repeat step 4 to the opposite side of the lens. (picture 2)
    • Lens is now separated from metal.
  9. Nikon Coolpix S3100 Camera Disassembly: 步骤 9 中的图像 1,3 Nikon Coolpix S3100 Camera Disassembly: 步骤 9 中的图像 2,3 Nikon Coolpix S3100 Camera Disassembly: 步骤 9 中的图像 3,3
    • Once you have all the parts separated, start cleaning them with an air compressor bottle. (as shown)
    • Using the provided straw, start spraying the parts. (pictures 2 and 3)
结论
2等其他人完成本指南。
Jorge
于03/11/15注册
1,170 声望
创作了7篇指南
团队
Colorado Springs, Team 2-4, Panko Spring 2015 Colorado Springs, Team 2-4, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G4
2 名成员
创作了13篇指南
一条评论
accidentally touched the wires for the cap even though i read the warning, can confirm, not fun
zettabyte - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 58
总计 3,502
