跳转到主内容
Nikon Coolpix S30 LCD Screen Replacement
你所需要的
  1. Nikon Coolpix S30 LCD Screen Replacement, Batteries: 步骤 1 中的图像 1,2 Nikon Coolpix S30 LCD Screen Replacement, Batteries: 步骤 1 中的图像 2,2
    • Slide the battery cover to the right.
    • The hinge is on the left side of the cover which will allow the cover to stay attached.
  2. Nikon Coolpix S30 LCD Screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix S30 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
  3. Nikon Coolpix S30 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the batteries by gently tipping the camera.
  4. Nikon Coolpix S30 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,1
    • FIRST: remove the batteries.
    • Unscrew the four screws around the corners of the camera. This can be done using the iFixit kit's T5 (star tip screwdriver)
  5. Nikon Coolpix S30 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Unscrew the screw on the left (silver) first. It can be removed with the same tip (T5)
    • Change screwdriver tip to iFixit kit's PH000. This removes the screw on the right (black) It is a small Phillips head.
  6. Nikon Coolpix S30 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Gently separate the back panel from the rest of the camera.
  7. Nikon Coolpix S30 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove screw connecting the top right of the screen to the mother board.
  8. Nikon Coolpix S30 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Spin the camera around and gently pull the screen towards you. This will allow easy access to components on the motherboard.
  9. Nikon Coolpix S30 LCD Screen Replacement: 步骤 9 中的图像 1,2 Nikon Coolpix S30 LCD Screen Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove connected strip by flipping up the small off-white plastic strip with tweezers.
    • Gently pull out the strip from the motherboard.
  10. Nikon Coolpix S30 LCD Screen Replacement: 步骤 10 中的图像 1,2 Nikon Coolpix S30 LCD Screen Replacement: 步骤 10 中的图像 2,2
    • Remove screw that is now in the top right corner. This will detach the screen entirely.
结论
另外一个人完成了本指南。
Cassie Hamm
于01/21/15注册
207 声望
创作了2篇指南
团队
Penn State, Team 2-4, Kaschak Winter 2015 Penn State, Team 2-4, Kaschak Winter 2015 的会员
PSU-KASCHAK-W15S2G4
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 1,088
