跳转到主内容
Nikon Coolpix S220 Battery and Memory Card Replacement
你所需要的
  1. Nikon Coolpix S220 Battery and Memory Card Replacement, Battery and Memory Card: 步骤 1 中的图像 1,1
    • Slide the battery and memory card cover (located on the bottom of the camera) to release it.
  2. Nikon Coolpix S220 Battery and Memory Card Replacement: 步骤 2 中的图像 1,1
    • To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • Remove with tweezers or your fingers.
  3. Nikon Coolpix S220 Battery and Memory Card Replacement: 步骤 3 中的图像 1,1
    • To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • You will be able to remove with your fingers.
结论
2等其他人完成本指南。
Shauna
于04/05/11注册
798 声望
创作了5篇指南
团队
Cal Poly, Team 12-32, Maness Spring 2011 Cal Poly, Team 12-32, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G32
4 名成员
创作了10篇指南
一条评论
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
bonitakale - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 28
总计 19,120
