跳转到主内容
Nikon Coolpix S220 Accessing the Motherboard
你所需要的
  1. Nikon Coolpix S220 Accessing the Motherboard, Outer Cover: 步骤 1 中的图像 1,1
    • Remove the two 2.8 mm screws on the left side of the camera.
  2. Nikon Coolpix S220 Accessing the Motherboard: 步骤 2 中的图像 1,1
    • Remove the four 2.8 mm screws on the right side of the camera.
  3. Nikon Coolpix S220 Accessing the Motherboard: 步骤 3 中的图像 1,1
    • Remove the three 4.1 mm screws on the bottom of the camera.
  4. Nikon Coolpix S220 Accessing the Motherboard: 步骤 4 中的图像 1,1
    • Gently lift the rear cover from the camera.
  5. Nikon Coolpix S220 Accessing the Motherboard, LCD: 步骤 5 中的图像 1,1
    • Gently lift the screen out of its place.
    • You will need to hold the screen slightly above the camera because it will still be attached to the camera by an orange ribbon cable.
  6. Nikon Coolpix S220 Accessing the Motherboard: 步骤 6 中的图像 1,1
    • Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
  7. Nikon Coolpix S220 Accessing the Motherboard: 步骤 7 中的图像 1,1
    • Slowly pull the screen from the camera.
  8. Nikon Coolpix S220 Accessing the Motherboard, Motherboard: 步骤 8 中的图像 1,1
    • Remove the four 3.8 mm screws located near the bottom right and top left of the LCD base plate.
  9. Nikon Coolpix S220 Accessing the Motherboard: 步骤 9 中的图像 1,1
    • Lift up silver LCD base plate
  10. Nikon Coolpix S220 Accessing the Motherboard: 步骤 10 中的图像 1,2 Nikon Coolpix S220 Accessing the Motherboard: 步骤 10 中的图像 2,2
    • Using tweezers, lift up the retaining flap on the ZIF connector securing the button panel ribbon cable.
    • Slide the button panel ribbon cable out of its socket on the motherboard.
结论
2等其他人完成本指南。
Shauna
于04/05/11注册
798 声望
创作了5篇指南
团队
Cal Poly, Team 12-32, Maness Spring 2011 Cal Poly, Team 12-32, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G32
4 名成员
创作了10篇指南
一条评论
It would be nice to have a guide for replacing the flash capacitor.
danwat1234 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 5,615
