跳转到主内容
Nikon Coolpix S210 LCD screen Replacement
你所需要的
  1. Nikon Coolpix S210 LCD screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 LCD screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix S210 LCD screen Replacement: 步骤 2 中的图像 2,2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
    Thank You!!! Amazing how easily I can complicate anything!! You are my hero. Retro picture taking ~ here I come!!
    Jennifer Curran - 回复
  3. Nikon Coolpix S210 LCD screen Replacement, Back Case: 步骤 3 中的图像 1,1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 LCD screen Replacement: 步骤 4 中的图像 1,1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 LCD screen Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 LCD screen Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix S210 LCD screen Replacement: 步骤 6 中的图像 2,2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. Nikon Coolpix S210 LCD screen Replacement, LCD screen: 步骤 7 中的图像 1,3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: 步骤 7 中的图像 2,3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: 步骤 7 中的图像 3,3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. Nikon Coolpix S210 LCD screen Replacement: 步骤 8 中的图像 1,1
    • Gently remove the LCD screen.
结论
2等其他人完成本指南。
Mallory Arend
于01/17/11注册
444 声望
创作了2篇指南
团队
Cal Poly, Team 5-17, Amido Winter 2011 Cal Poly, Team 5-17, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G17
6 名成员
创作了12篇指南
一条评论
Funcionou conforme descrito! Funciona para a Nikon Coolpix S203
geral - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 3,977
