跳转到主内容
Nikon Coolpix S210 Circuit Board Replacement
你所需要的
  1. Nikon Coolpix S210 Circuit Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 Circuit Board Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix S210 Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. Nikon Coolpix S210 Circuit Board Replacement, Back Case: 步骤 3 中的图像 1,1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 Circuit Board Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix S210 Circuit Board Replacement: 步骤 6 中的图像 2,2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. Nikon Coolpix S210 Circuit Board Replacement, LCD screen: 步骤 7 中的图像 1,3 Nikon Coolpix S210 Circuit Board Replacement, LCD screen: 步骤 7 中的图像 2,3 Nikon Coolpix S210 Circuit Board Replacement, LCD screen: 步骤 7 中的图像 3,3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. Nikon Coolpix S210 Circuit Board Replacement: 步骤 8 中的图像 1,1
    • Gently remove the LCD screen.
  9. Nikon Coolpix S210 Circuit Board Replacement, Circuit Board Cover: 步骤 9 中的图像 1,1
    • After removing the LCD screen, unscrew the four 3.8mm screws that hold down the metal plate
    • Unscrew the 2.5mm screw next to the wrist-strap mount.
  10. Nikon Coolpix S210 Circuit Board Replacement: 步骤 10 中的图像 1,2 Nikon Coolpix S210 Circuit Board Replacement: 步骤 10 中的图像 2,2
    • Position the camera with the lens facing down and the shutter button facing you.
    • Lift the metal plate away from the camera without removing it fully. There is a ribbon attaching the edge of the plate to the camera.
    • The ribbon is being held in place by a black latch.
    • Carefully pry the spudger under the black latch and lift gently upward. The ribbon will slide out easily.
    • With the ribbon unlatched, the entire metal plate should now be detached.
  11. Nikon Coolpix S210 Circuit Board Replacement, Circuit Board: 步骤 11 中的图像 1,1
    • Desolder the marked areas. For desoldering instructions go -here-
  12. Nikon Coolpix S210 Circuit Board Replacement: 步骤 12 中的图像 1,1
    • Place the spudger underneath the small black tape as shown. Gently lift the spudger up to remove the tape.
  13. Nikon Coolpix S210 Circuit Board Replacement: 步骤 13 中的图像 1,2 Nikon Coolpix S210 Circuit Board Replacement: 步骤 13 中的图像 2,2
    • Remove the 3.8mm screw from the circuit board.
结论
2等其他人完成本指南。
John Bowers
于01/18/11注册
874 声望
创作了2篇指南
团队
Cal Poly, Team 5-17, Amido Winter 2011 Cal Poly, Team 5-17, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G17
6 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 14
总计 3,660
