跳转到主内容
Nikon Coolpix S210 Back Case Replacement
你所需要的
  1. Nikon Coolpix S210 Back Case Replacement, Battery: 步骤 1 中的图像 1,1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 Back Case Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix S210 Back Case Replacement: 步骤 2 中的图像 2,2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
    Thank You!!! Amazing how easily I can complicate anything!! You are my hero. Retro picture taking ~ here I come!!
    Jennifer Curran - 回复
  3. Nikon Coolpix S210 Back Case Replacement, Back Case: 步骤 3 中的图像 1,1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 Back Case Replacement: 步骤 4 中的图像 1,1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 Back Case Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 Back Case Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix S210 Back Case Replacement: 步骤 6 中的图像 2,2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
结论
To reassemble your device, follow these instructions in reverse order, paying careful attention to the locations of the different sizes of screws.
另外一个人完成了本指南。
Paul Doyle
于01/20/11注册
504 声望
创作了3篇指南
团队
Cal Poly, Team 5-17, Amido Winter 2011 Cal Poly, Team 5-17, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G17
6 名成员
创作了12篇指南
1指南评论
What about the front case so I can replace the flash board on top?
danwat1234 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 2,339
