跳转到主内容
Nikon Coolpix P530 Tripod Mount Replacement
你所需要的
  1. Nikon Coolpix P530 Tripod Mount Replacement, Battery: 步骤 1 中的图像 1,1
    • Identify the battery chamber found at the bottom of the device.
    • Ensure the camera is turned off before conducting any maintenance on the device.
  2. Nikon Coolpix P530 Tripod Mount Replacement: 步骤 2 中的图像 1,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 2 中的图像 2,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 2 中的图像 3,3
    • Slide the switch to the left to open the battery chamber using your fingertip or plastic opening tools.
    • The spring loaded battery chamber door will swing open after the switch is moved.
  3. Nikon Coolpix P530 Tripod Mount Replacement: 步骤 3 中的图像 1,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 3 中的图像 2,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 3 中的图像 3,3
    • Depress the yellow spring loaded tab holding the battery in place using your fingertip or plastic opening tools.
    • After the yellow tab is depressed, the battery should partially eject from the camera.
  4. Nikon Coolpix P530 Tripod Mount Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 4 中的图像 2,2
    • Gently remove the battery from the chamber.
  5. Nikon Coolpix P530 Tripod Mount Replacement, Back Cover: 步骤 5 中的图像 1,3 Nikon Coolpix P530 Tripod Mount Replacement, Back Cover: 步骤 5 中的图像 2,3 Nikon Coolpix P530 Tripod Mount Replacement, Back Cover: 步骤 5 中的图像 3,3
    • Remove the six 4mm screws highlighted in red with the Phillips #000 screwdriver.
    • Remove the 5mm screw highlighted in orange with the Phillips #000 screwdriver.
  6. Nikon Coolpix P530 Tripod Mount Replacement: 步骤 6 中的图像 1,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 6 中的图像 2,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 6 中的图像 3,3
    • Pop up the camera flash using the button below the lightning bolt on the left side of the camera.
    • Identify the small notch below the camera flash where the body of the camera and the back cover join.
    • Use plastic opening tools to pry the darker plastic piece under the camera flash from the lighter plastic camera body.
  7. Nikon Coolpix P530 Tripod Mount Replacement: 步骤 7 中的图像 1,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 7 中的图像 2,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 7 中的图像 3,3
    • Gently pry with a plastic opening tool around the perimeter of the camera.
    • The plastic HDMI cover can become loose and fall off during this step. Once the back cover is free from the camera you may remove this piece to store in a safe place.
  8. Nikon Coolpix P530 Tripod Mount Replacement: 步骤 8 中的图像 1,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 8 中的图像 2,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • Gently lift the back cover away from the camera body.
    • A gold ribbon cable will join the back cover of the camera to the internal electronic components. Be careful not to remove the back cover without removing the cable since this part can easily break.
    • To remove the ribbon cable, gently pull the connector from the camera's internal electronic components using a pair of tweezers.
    • Flip the orange bar securing the ribbon cable upwards to allow for safe removal.
  9. Nikon Coolpix P530 Tripod Mount Replacement: 步骤 9 中的图像 1,1
    • After the ribbon cable is removed from the camera body, the cover can be completely removed.
  10. Nikon Coolpix P530 Tripod Mount Replacement, Tripod Mount: 步骤 10 中的图像 1,1
    • Identify two the remaining 4mm screws to be removed using the Philips #000 screwdriver.
  11. Nikon Coolpix P530 Tripod Mount Replacement: 步骤 11 中的图像 1,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 11 中的图像 2,3 Nikon Coolpix P530 Tripod Mount Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Once these screws have been removed, use tweezers to take out the tripod mount.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 1,165
