简介
A broken LCD bracket could affect the placement of the LCD screen. This guide will show the replacement procedure for the LCD bracket. This guide also serves as a prerequisite for replacing the CCD sensor and the zoom lens unit.
你所需要的
Remove the six 4mm screws highlighted in red with the Phillips #000 screwdriver.
Remove the 5mm screw highlighted in orange with the Phillips #000 screwdriver.
Pop up the camera flash using the button below the lightning bolt on the left side of the camera.
Identify the small notch below the camera flash where the body of the camera and the back cover join.
Use plastic opening tools to pry the darker plastic piece under the camera flash from the lighter plastic camera body.
在这个步骤中使用的工具:Tweezers$4.99
Gently lift the back cover away from the camera body.
A gold ribbon cable will join the back cover of the camera to the internal electronic components. Be careful not to remove the back cover without removing the cable since this part can easily break.
To remove the ribbon cable, gently pull the connector from the camera's internal electronic components using a pair of tweezers.
Remove the six 4mm screws highlighted in red using the Philips #000 screwdriver.
Remove the 6mm screw highlighted in orange using the Philips #000 screwdriver.
另外一个人完成了本指南。
