跳转到主内容
Nikon Coolpix P530 Battery Replacement
你所需要的
  1. Nikon Coolpix P530 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Identify the battery chamber found at the bottom of the device.
    • Ensure the camera is turned off before conducting any maintenance on the device.
  2. Nikon Coolpix P530 Battery Replacement: 步骤 2 中的图像 1,3 Nikon Coolpix P530 Battery Replacement: 步骤 2 中的图像 2,3 Nikon Coolpix P530 Battery Replacement: 步骤 2 中的图像 3,3
    • Slide the switch to the left to open the battery chamber using your fingertip or plastic opening tools.
    • The spring loaded battery chamber door will swing open after the switch is moved.
  3. Nikon Coolpix P530 Battery Replacement: 步骤 3 中的图像 1,3 Nikon Coolpix P530 Battery Replacement: 步骤 3 中的图像 2,3 Nikon Coolpix P530 Battery Replacement: 步骤 3 中的图像 3,3
    • Depress the yellow spring loaded tab holding the battery in place using your fingertip or plastic opening tools.
    • After the yellow tab is depressed, the battery should partially eject from the camera.
  4. Nikon Coolpix P530 Battery Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix P530 Battery Replacement: 步骤 4 中的图像 2,2
    • Gently remove the battery from the chamber.
结论
3等其他人完成本指南。
3条评论
Thanks. Just checking the camera issues.
Suzanne von Leuschner - 回复
I can’t get the battery out of my camera. I've had the camera for 5 years with no previous problems. Any suggestions?
Bonnie Laub - 回复
top of the battery gets very hot when inserted .Is this normal?
Lowell Schiller - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 39
总计 3,793
