跳转到主内容
Nikon Coolpix P510 Lens Casing Replacement
你所需要的
  1. Nikon Coolpix P510 Lens Casing Replacement, Lens Assembly: 步骤 1 中的图像 1,2 Nikon Coolpix P510 Lens Casing Replacement, Lens Assembly: 步骤 1 中的图像 2,2
    • Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
    • On the thumb grip, remove the one 4mm PH00 Philips screw.
  2. Nikon Coolpix P510 Lens Casing Replacement: 步骤 2 中的图像 1,1
    • With the camera upside down, remove the three 3mm PH00 Philips screws on the left side.
    • One of the screws are under the HDMI and A/V Out cover.
  3. Nikon Coolpix P510 Lens Casing Replacement: 步骤 3 中的图像 1,1
    • On the opposite side of the camera, remove the two 3mm PH00 Philips screws.
  4. Nikon Coolpix P510 Lens Casing Replacement: 步骤 4 中的图像 1,3 Nikon Coolpix P510 Lens Casing Replacement: 步骤 4 中的图像 2,3 Nikon Coolpix P510 Lens Casing Replacement: 步骤 4 中的图像 3,3
    • Open the flash and use a plastic opening tool to pop the tab under it as shown.
    • Now pull the casing apart.
    • The tripod attachment may fall out on its own, or you will need to pull it out.
  5. Nikon Coolpix P510 Lens Casing Replacement: 步骤 5 中的图像 1,2 Nikon Coolpix P510 Lens Casing Replacement: 步骤 5 中的图像 2,2
    • Unplug the two ribbon cables to completely detach the back.
  6. Nikon Coolpix P510 Lens Casing Replacement: 步骤 6 中的图像 1,3 Nikon Coolpix P510 Lens Casing Replacement: 步骤 6 中的图像 2,3 Nikon Coolpix P510 Lens Casing Replacement: 步骤 6 中的图像 3,3
    • With the back separated, you need to remove six 3mm PH000 Philips screws with a Philips screwdriver.
    • Remove one 5mm PH00 Philips screw
    • To remove the top right corner screw, you may need to lift the corner of the case to gain access to it.
    • With all the screws out, the metal plate should simply lift off.
  7. Nikon Coolpix P510 Lens Casing Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix P510 Lens Casing Replacement: 步骤 7 中的图像 2,2
    • With the metal plate off, unplug this ribbon cable from the motherboard.
    • To remove the flat-topped connector, you simply lift it up to unplug it.
  8. Nikon Coolpix P510 Lens Casing Replacement: 步骤 8 中的图像 1,3 Nikon Coolpix P510 Lens Casing Replacement: 步骤 8 中的图像 2,3 Nikon Coolpix P510 Lens Casing Replacement: 步骤 8 中的图像 3,3
    • To get the lens assembly out, you need to remove four 6mm PH00 Philips screws
  9. Nikon Coolpix P510 Lens Casing Replacement: 步骤 9 中的图像 1,2 Nikon Coolpix P510 Lens Casing Replacement: 步骤 9 中的图像 2,2
    • With the support screws out, you can simply slide the assembly out of the casing.
  10. Nikon Coolpix P510 Lens Casing Replacement: 步骤 10 中的图像 1,3 Nikon Coolpix P510 Lens Casing Replacement: 步骤 10 中的图像 2,3 Nikon Coolpix P510 Lens Casing Replacement: 步骤 10 中的图像 3,3
    • If you are moving on to take the lens casing off, you do not need to do this step.
    • With the assembly out we need to take of this last piece by removing the three 3mm PH000 Philips screws.
  11. Nikon Coolpix P510 Lens Casing Replacement, Lens Casing: 步骤 11 中的图像 1,2 Nikon Coolpix P510 Lens Casing Replacement, Lens Casing: 步骤 11 中的图像 2,2
    • Remove five PH00 Philips screws with a Philips screwdriver.
  12. Nikon Coolpix P510 Lens Casing Replacement: 步骤 12 中的图像 1,1
    • Separate the lens casing from the front.
    • The switch on the side simply slides off of the front casing.
结论
3等其他人完成本指南。
Brian Hulsey
于03/31/15注册
1,506 声望
创作了6篇指南
团队
Colorado Springs, Team 2-2, Panko Spring 2015 Colorado Springs, Team 2-2, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 33
总计 3,308
