本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will tell you how to replace your motherboard
你所需要的
Flip the camera upside down (have the side with the buttons facing away from you)
Look for the side with the triangle icon with three lines in it, this is the battery door. Add pressure and slide this door slightly until it clicks and pops open.
Once the door clicks, you can open it to reveal the slots holding the memory card and the battery.
Focusing on the larger slot, this holds the battery. Push the orange tab away from the slot, this will eject the old battery if one was previously inside.
Once this slot is open, you can place the new battery inside.
Remove the screw to the right of the flash.
Remove the screw to the right of the microphone on the bottom. (0.124in)
