跳转到主内容
加入维修社区 - 创建账户
Nikon Coolpix P4 LCD Screen Replacement
你所需要的
  1. Nikon Coolpix P4 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the camera upside down (have the side with the buttons facing away from you)
    • Look for the side with the triangle icon with three lines in it, this is the battery door. Add pressure and slide this door slightly until it clicks and pops open.
  2. Nikon Coolpix P4 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Once the door clicks, you can open it to reveal the slots holding the memory card and the battery.
    • Focusing on the larger slot, this holds the battery. Push the orange tab away from the slot, this will eject the old battery if one was previously inside.
    • Once this slot is open, you can place the new battery inside.
    • Make sure to close the orange tab to secure it in place!
  3. Nikon Coolpix P4 LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 1,1
    • Remove the four 2.2 mm screws located on the bottom of the camera.
  4. Nikon Coolpix P4 LCD Screen Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix P4 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the two 2.9 mm screws from the side panel.
    • Remove the side panel.
  5. Nikon Coolpix P4 LCD Screen Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix P4 LCD Screen Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix P4 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the two 5 mm screws from the right side panel.
    • Remove the panel from the right side.
    • Remove the single 2.1 mm screw set underneath the panel.
  6. Nikon Coolpix P4 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the two 4.8 mm screws attaching the back panel to the body on the left side.
  7. Nikon Coolpix P4 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Gently pull off the back cover.
  8. Nikon Coolpix P4 LCD Screen Replacement: 步骤 8 中的图像 1,2 Nikon Coolpix P4 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the three 4.8 mm screws from the A/V out tab on the left side.
    • Remove the tab.
  9. Nikon Coolpix P4 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the two 4.6 mm screws attaching the front panel to the body on the left side.
  10. Nikon Coolpix P4 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Flip up the front panel.
    • Potential for device damage. There should be wires still attaching the panel to the body. DO NOT TRY TO PULL OFF COMPLETELY.
  11. Nikon Coolpix P4 LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Remove the 2.2 mm screw.
    • Remove the 2.9 mm screw.
    • Remove the 2.1 mm screw.
  12. Nikon Coolpix P4 LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Carefully pull the orange LCD connector up and out of the port.
    • Be careful to pull vertically while pushing the black tab upwards
  13. Nikon Coolpix P4 LCD Screen Replacement: 步骤 13 中的图像 1,1
    • Remove the 3.1 mm screw below the LCD.
  14. Nikon Coolpix P4 LCD Screen Replacement: 步骤 14 中的图像 1,1
    • Carefully pull out the plug connecting the LCD to the motherboard.
  15. Nikon Coolpix P4 LCD Screen Replacement: 步骤 15 中的图像 1,1
    • Remove the LCD from the camera body.
结论
Luke Baumann
于04/13/11注册
128 声望
创作了5篇指南
团队
Cal Poly, Team 8-5, Regan Spring 2011 Cal Poly, Team 8-5, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G5
4 名成员
创作了10篇指南
1指南评论
Where did you get the screen?
jharrison - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 68
总计 3,560
