跳转到主内容
Nikon Coolpix P100 Display Screen Replacement
你所需要的
  1. Nikon Coolpix P100 Display Screen Replacement, Display Screen: 步骤 1 中的图像 1,3 Nikon Coolpix P100 Display Screen Replacement, Display Screen: 步骤 1 中的图像 2,3 Nikon Coolpix P100 Display Screen Replacement, Display Screen: 步骤 1 中的图像 3,3
    • Flip the camera upside down so that the side with the serial number is face up.
    • Pull back the display panel. Orient the panel so that you are able to view the back of it.
  2. Nikon Coolpix P100 Display Screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix P100 Display Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the two screws closest to the piece connecting the panel to the camera with a Phillips #1 screwdriver.
  3. Nikon Coolpix P100 Display Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the cover that was unscrewed in the last step.
  4. Nikon Coolpix P100 Display Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the remaining four screws on the outermost corners of the panel using a Phillips #1 screwdriver.
  5. Nikon Coolpix P100 Display Screen Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix P100 Display Screen Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix P100 Display Screen Replacement: 步骤 5 中的图像 3,3
    • Use a plastic opening tool to pry open the back panel of the display screen.
  6. Nikon Coolpix P100 Display Screen Replacement: 步骤 6 中的图像 1,3 Nikon Coolpix P100 Display Screen Replacement: 步骤 6 中的图像 2,3 Nikon Coolpix P100 Display Screen Replacement: 步骤 6 中的图像 3,3
    • Carefully unhook the ribbon that attaches the panel to the camera.
    • Remove the top black panel cover.
  7. Nikon Coolpix P100 Display Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the two screws on the panel that are closest to the ribbon cable using a Phillips #1 screwdriver.
  8. Nikon Coolpix P100 Display Screen Replacement: 步骤 8 中的图像 1,1
    • Remove the other two screws on the opposite side of the panel using a Phillips #1 screwdriver.
  9. Nikon Coolpix P100 Display Screen Replacement: 步骤 9 中的图像 1,2 Nikon Coolpix P100 Display Screen Replacement: 步骤 9 中的图像 2,2
    • Separate the metal portion of the screen from the plastic portion.
  10. Nikon Coolpix P100 Display Screen Replacement: 步骤 10 中的图像 1,2 Nikon Coolpix P100 Display Screen Replacement: 步骤 10 中的图像 2,2
    • Carefully remove the ribbon connector cable from the metal portion of the display.
    • Remove the display from the rest of the device.
结论
5等其他人完成本指南。
Rikki Brown
于01/09/15注册
267 声望
创作了2篇指南
团队
USF Tampa, Team 1-1, Tanski Winter 2015 USF Tampa, Team 1-1, Tanski Winter 2015 的会员
USFT-TANSKI-W15S1G1
3 名成员
创作了8篇指南
3条评论
This guide help me to change my screen on Nikon P100 with out to much trouble, however I found step 7 unnecessary.
David Fyock - 回复
Hello, I've a problem during the re-mount of the display. Someone can help me? Thanks in advance! Mark
cwmark56 - 回复
I can't reconnect the connector on the step 10. Can you help me?
cwmark56 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 42
总计 2,731
