跳转到主内容
Nikon Coolpix L840 Flash Replacement
你所需要的
  1. Nikon Coolpix L840 Flash Replacement, Flash: 步骤 1 中的图像 1,1
    • Press the flash button on the side of the camera to allow the flash to spring upward.
  2. Nikon Coolpix L840 Flash Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L840 Flash Replacement: 步骤 2 中的图像 2,2
    • Unscrew the two black, 4mm screws with a Philips 000. (There should be one screw on each side of the camera).
  3. Nikon Coolpix L840 Flash Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix L840 Flash Replacement: 步骤 3 中的图像 2,2
    • Remove the back case of the flash by lifting it off of the flash.
    • The back half cover has a little tail that keeps it locked in place. Wiggling the back cover around may help unhook the tail.
  4. Nikon Coolpix L840 Flash Replacement: 步骤 4 中的图像 1,1
    • Push the flash inward to pop the flash out of its front case. Since the back case is removed, the flash should pop out from the back.
  5. Nikon Coolpix L840 Flash Replacement: 步骤 5 中的图像 1,1
    • The see-through protective flash covering is stuck on to the flash with thin, double-sided tape. Pull apart the two components to access the flash.
结论
团队
Cal Poly, Team 1-11, Maness Spring 2016 Cal Poly, Team 1-11, Maness Spring 2016 的会员
CPSU-MANESS-S16S1G11
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,069
