跳转到主内容
Nikon Coolpix L840 Buttons Replacement
你所需要的
  1. Nikon Coolpix L840 Buttons Replacement, Motherboard: 步骤 1 中的图像 1,3 Nikon Coolpix L840 Buttons Replacement, Motherboard: 步骤 1 中的图像 2,3 Nikon Coolpix L840 Buttons Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Buttons Replacement: 步骤 2 中的图像 1,1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Buttons Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix L840 Buttons Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
  4. Nikon Coolpix L840 Buttons Replacement, Buttons: 步骤 4 中的图像 1,1
    • Unscrew the two, right-most, 2 mm screws with a Philips 000.
    • Unscrew the left-most, 4 mm screw with a Philips 000.
  5. Nikon Coolpix L840 Buttons Replacement: 步骤 5 中的图像 1,1
    • Slide off the button panel in the marked direction.
  6. Nikon Coolpix L840 Buttons Replacement: 步骤 6 中的图像 1,1
    • Flip to the front side of the button panel to access the button sensors.
结论
另外一个人完成了本指南。
Abraham Lozano
于04/11/16注册
595 声望
创作了4篇指南
团队
Cal Poly, Team 1-11, Maness Spring 2016 Cal Poly, Team 1-11, Maness Spring 2016 的会员
CPSU-MANESS-S16S1G11
4 名成员
创作了10篇指南
一条评论
Where can I get a replacement board for the buttons?
rush - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 38
总计 2,281
