跳转到主内容
Nikon Coolpix L830 LCD Monitor Replacement
你所需要的
  1. Nikon Coolpix L830 LCD Monitor Replacement, LCD Monitor: 步骤 1 中的图像 1,1
    • Use a Phillips head P000 screwdriver to remove the four 3.0 mm Phillips screws on the back of the monitor.
  2. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips head P000 screwdriver to remove the two 3.0 mm Phillips screws on the hinge cover.
  3. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix L830 LCD Monitor Replacement: 步骤 3 中的图像 2,2
    • Remove the top hinge cover.
    • The top hinge cover contains screw holes.
    • Remove the bottom hinge cover.
    • The bottom hinge cover contains no screw holes.
  4. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 4 中的图像 1,1
    • Remove the back cover of the LCD monitor with your hands or a plastic opening tool.
    • The cover will slide down the hinge, but it will not be completely removed.
  5. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 5 中的图像 1,2 Nikon Coolpix L830 LCD Monitor Replacement: 步骤 5 中的图像 2,2
    • Use your thumb to gently pull the small flex ribbon wire connector from its socket.
    • Use your thumb to gently pull the wide flex ribbon wire connector from its socket.
  6. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to remove the front cover of the LCD monitor, allowing the monitor to be completely be released.
  7. Nikon Coolpix L830 LCD Monitor Replacement: 步骤 7 中的图像 1,1
    • Gently remove the old, damaged LCD monitor.
结论
另外一个人完成了本指南。
Blake Johnson
于10/28/16注册
359 声望
创作了2篇指南
团队
Baylor, Team 4-4, Williams Fall 2016 Baylor, Team 4-4, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G4
3 名成员
创作了10篇指南
2指南评论
I cant remove two of the screws. Help
jo Hogan - 回复
Très bien pour démonter , mais pour remonter les nappes, notamment la moins large, je n'arrive pas à l'insérer !
Avez vous une technique à me proposer ?
Michel Cassel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 46
总计 3,039
