简介
To reach internal components of the Nikon Coolpix L830 such as the motherboard and shutter button, first removing the back outer surface component is necessary. Following the steps of this prerequisite-only guide will allow you to remove the back casing and access internal components.
你所需要的
Use a Phillips #000 screwdriver to unscrew the two 3.0mm Phillips screws located on the side of the camera with the HDMI port.
即将完成!
结论
