跳转到主内容
Nikon Coolpix L820 Shutter Button Replacement
你所需要的
  1. Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: 步骤 1 中的图像 1,3 Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: 步骤 1 中的图像 2,3 Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: 步骤 1 中的图像 3,3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
  2. Nikon Coolpix L820 Shutter Button Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L820 Shutter Button Replacement: 步骤 2 中的图像 2,2
    • Remove the front top Phillips screw with the screwdriver.
    • Open the empty battery slot on the bottom of the camera, revealing four additional screws.
    • Unscrew the four Phillips screws with the screwdriver.
  3. Nikon Coolpix L820 Shutter Button Replacement: 步骤 3 中的图像 1,3 Nikon Coolpix L820 Shutter Button Replacement: 步骤 3 中的图像 2,3 Nikon Coolpix L820 Shutter Button Replacement: 步骤 3 中的图像 3,3
    • Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
    • Be sure to only apply pressure to the casing panels and not the sensitive internal electronics.
    • Once the rear housing is separated, the settings buttons will be accessible for replacement.
  4. Nikon Coolpix L820 Shutter Button Replacement, LCD screen: 步骤 4 中的图像 1,3 Nikon Coolpix L820 Shutter Button Replacement, LCD screen: 步骤 4 中的图像 2,3 Nikon Coolpix L820 Shutter Button Replacement, LCD screen: 步骤 4 中的图像 3,3
    • Remove the front casing to expose the LCD screen and wires.
    • Do not damage the exposed wires.
  5. Nikon Coolpix L820 Shutter Button Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix L820 Shutter Button Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix L820 Shutter Button Replacement: 步骤 5 中的图像 3,3
    • Using the tweezers, lift the hinges connecting the two ribbon wires to the camera.
  6. Nikon Coolpix L820 Shutter Button Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix L820 Shutter Button Replacement: 步骤 6 中的图像 2,2
    • Once the flexible ribbon wires are disconnected, remove the LCD screen.
  7. Nikon Coolpix L820 Shutter Button Replacement, Shutter Button: 步骤 7 中的图像 1,1
    • Remove these five Phillips screws, from the back of the camera, with the Phillips screwdriver.
  8. Nikon Coolpix L820 Shutter Button Replacement: 步骤 8 中的图像 1,1
    • Using the pointed edge of the spudger, lift the hinge that secures this flex circuit. This will unfasten the flexible ribbon wire.
  9. Nikon Coolpix L820 Shutter Button Replacement: 步骤 9 中的图像 1,1
    • Remove the panel containing the shutter and zoom slider, by lifting it up.
  10. Nikon Coolpix L820 Shutter Button Replacement: 步骤 10 中的图像 1,1
    • Remove the metal cover using tweezers to allow access to the shutter button.
    • Replace shutter button.
结论
2等其他人完成本指南。
Jimmy Kendall
于03/23/15注册
137 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-4, Miles Spring 2015 UMass Dartmouth, Team 1-4, Miles Spring 2015 的会员
UMASSD-MILES-S15S1G4
3 名成员
创作了10篇指南
3条评论
Muy bueno pero falta documentar 3 tornillos.
1. En el paso 1, en la tercera foto debajo del sticker del código de barras.
2. En el paso 2, justo en el fondo del compartimento de una de las baterías (la del extremo). Incluso se alcanza a apreciar en la foto.
3. En el paso 8, en esa misma pieza de metal a un lado está el otro tornillo.
cyrez_1509 - 回复
My shutter button still works but doesn’t give feedback. It’s hard to tell when I’ve taken a picture because it doesn’t “click.” I’m wondering if that’s something that can be fixed, but I can’t tell if the mechanism for that feedback is in the mechanical portion above (and maybe a piece of metal broke) or built into the switch soldered on the circuit board.
JM Palacios - 回复
Dove si può acquistare il bottone a buon prezzo? grazie
Where can you buy the button at a good price? Thank you
Massimino Diquarto - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 3,235
