跳转到主内容
Nikon Coolpix L820 Settings Buttons Replacement
你所需要的
  1. Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: 步骤 1 中的图像 1,3 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: 步骤 1 中的图像 2,3 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: 步骤 1 中的图像 3,3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are 10 screws around the casing. 3 are located on the left side of the camera, 6 are located on the bottom near the product label, and 1 is located on the right side of the camera.
  2. Nikon Coolpix L820 Settings Buttons Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L820 Settings Buttons Replacement: 步骤 2 中的图像 2,2
    • Next, remove the screw held on top of the camera above the Nikon logo.
    • Moving to the bottom of the camera, open the empty battery slot, and locate the 4 screws in the compartment. Begin removing the 4 screws located within.
  3. Nikon Coolpix L820 Settings Buttons Replacement: 步骤 3 中的图像 1,3 Nikon Coolpix L820 Settings Buttons Replacement: 步骤 3 中的图像 2,3 Nikon Coolpix L820 Settings Buttons Replacement: 步骤 3 中的图像 3,3
    • Using the spudger, begin prying the case from the device, carefully separating the rear housing from the camera assembly. Once the rear housing is separated, the camera's physical buttons will be accessible for replacement.
    • Be sure to only apply pressure to the casing panels, not internal electronics. Doing so can damage the internal components of the camera.
结论
另外一个人完成了本指南。
Marc
于03/23/15注册
430 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-4, Miles Spring 2015 UMass Dartmouth, Team 1-4, Miles Spring 2015 的会员
UMASSD-MILES-S15S1G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 21
总计 1,368
