跳转到主内容
Nikon Coolpix L820 LCD Replacement
你所需要的
  1. Nikon Coolpix L820 LCD Replacement, Settings Buttons: 步骤 1 中的图像 1,3 Nikon Coolpix L820 LCD Replacement, Settings Buttons: 步骤 1 中的图像 2,3 Nikon Coolpix L820 LCD Replacement, Settings Buttons: 步骤 1 中的图像 3,3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
  2. Nikon Coolpix L820 LCD Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L820 LCD Replacement: 步骤 2 中的图像 2,2
    • Remove the front top Phillips screw with the screwdriver.
    • Open the empty battery slot on the bottom of the camera, revealing four additional screws.
    • Unscrew the four Phillips screws with the screwdriver.
  3. Nikon Coolpix L820 LCD Replacement: 步骤 3 中的图像 1,3 Nikon Coolpix L820 LCD Replacement: 步骤 3 中的图像 2,3 Nikon Coolpix L820 LCD Replacement: 步骤 3 中的图像 3,3
    • Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
    • Be sure to only apply pressure to the casing panels and not the sensitive internal electronics.
    • Once the rear housing is separated, the settings buttons will be accessible for replacement.
  4. Nikon Coolpix L820 LCD Replacement, LCD screen: 步骤 4 中的图像 1,3 Nikon Coolpix L820 LCD Replacement, LCD screen: 步骤 4 中的图像 2,3 Nikon Coolpix L820 LCD Replacement, LCD screen: 步骤 4 中的图像 3,3
    • Remove the front casing to expose the LCD screen and wires.
    • Do not damage the exposed wires.
  5. Nikon Coolpix L820 LCD Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix L820 LCD Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix L820 LCD Replacement: 步骤 5 中的图像 3,3
    • Using the tweezers, lift the hinges connecting the two ribbon wires to the camera.
  6. Nikon Coolpix L820 LCD Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix L820 LCD Replacement: 步骤 6 中的图像 2,2
    • Once the flexible ribbon wires are disconnected, remove the LCD screen.
结论
2等其他人完成本指南。
Lucas Otto
于03/23/15注册
107 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-4, Miles Spring 2015 UMass Dartmouth, Team 1-4, Miles Spring 2015 的会员
UMASSD-MILES-S15S1G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 2,297
