跳转到主内容
Nikon Coolpix L810 Motherboard Replacement
你所需要的
  1. Nikon Coolpix L810 Motherboard Replacement, LCD: 步骤 1 中的图像 1,2 Nikon Coolpix L810 Motherboard Replacement, LCD: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button.
    • Use of precision tweezers to help remove loosened screws is suggested.
  2. Nikon Coolpix L810 Motherboard Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L810 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
  3. Nikon Coolpix L810 Motherboard Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix L810 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove three 5 mm Phillips #000 screws on the bottom end of the camera.
  4. Nikon Coolpix L810 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
  5. Nikon Coolpix L810 Motherboard Replacement: 步骤 5 中的图像 1,2 Nikon Coolpix L810 Motherboard Replacement: 步骤 5 中的图像 2,2
    • With the LCD screen facing towards you, flip the screen to the right.
  6. Nikon Coolpix L810 Motherboard Replacement: 步骤 6 中的图像 1,3 Nikon Coolpix L810 Motherboard Replacement: 步骤 6 中的图像 2,3 Nikon Coolpix L810 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Remove three 5 mm Phillips #000 screws located on the bracket.
    • Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed.
  7. Nikon Coolpix L810 Motherboard Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix L810 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
  8. Nikon Coolpix L810 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,3 Nikon Coolpix L810 Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,3 Nikon Coolpix L810 Motherboard Replacement, Motherboard: 步骤 8 中的图像 3,3
    • Remove three 5 mm Phillips #000 screws bordering the motherboard.
  9. Nikon Coolpix L810 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the plastic component located directly behind the flash from its rubberized holder.
  10. Nikon Coolpix L810 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the electric tape covering the wires.
  11. Nikon Coolpix L810 Motherboard Replacement: 步骤 11 中的图像 1,3 Nikon Coolpix L810 Motherboard Replacement: 步骤 11 中的图像 2,3 Nikon Coolpix L810 Motherboard Replacement: 步骤 11 中的图像 3,3
    • Unsolder all the wires that are on the top of the motherboard near the flash component.
  12. Nikon Coolpix L810 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Unsolder the wires on the bottom end of the motherboard.
结论
2等其他人完成本指南。
Emilio Mena
于01/14/15注册
752 声望
创作了4篇指南
团队
UW Tacoma, Team 3-1, Rose Winter 2015 UW Tacoma, Team 3-1, Rose Winter 2015 的会员
UWT-ROSE-W15S3G1
4 名成员
创作了8篇指南
4条评论
The guide is incomplete! Do not try to remove the mobo for it is soldered to some other tiny board under the on/off switch. Trying to remove the mobo after just unscrewing it, may guide to certain and permanent destruction of both PCBs!!!
symeonleriou - 回复
any clue how to get tiny mobo out with mobo after taking screw out of tiny one at on/off switch?
jon baker - 回复
This guide should be for beginners, Mr. Symeon Leriou, and you will not only write "Mobo", but also motherboard or Mainboard or Hauptplatine (deutsch)
But I agree with you that it is not complete.
The motherboard is soldered to the on / off board (power supply for the batteries).
Soldering again is almost impossible ...
lothar4460 - 回复
Exactly! The guide is GOOD but it is incomplete!
The solder removal is insufficient to release de motherboard.
How to do it?
ramos.eng - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 31
总计 3,118
