跳转到主内容
Nikon Coolpix L810 LCD Replacement
你所需要的
  1. Nikon Coolpix L810 LCD Replacement, LCD: 步骤 1 中的图像 1,2 Nikon Coolpix L810 LCD Replacement, LCD: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button.
    • Use of precision tweezers to help remove loosened screws is suggested.
  2. Nikon Coolpix L810 LCD Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L810 LCD Replacement: 步骤 2 中的图像 2,2
    • Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
  3. Nikon Coolpix L810 LCD Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix L810 LCD Replacement: 步骤 3 中的图像 2,2
    • Remove three 5 mm Phillips #000 screws on the bottom end of the camera.
  4. Nikon Coolpix L810 LCD Replacement: 步骤 4 中的图像 1,1
    • Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
  5. Nikon Coolpix L810 LCD Replacement: 步骤 5 中的图像 1,2 Nikon Coolpix L810 LCD Replacement: 步骤 5 中的图像 2,2
    • With the LCD screen facing towards you, flip the screen to the right.
  6. Nikon Coolpix L810 LCD Replacement: 步骤 6 中的图像 1,3 Nikon Coolpix L810 LCD Replacement: 步骤 6 中的图像 2,3 Nikon Coolpix L810 LCD Replacement: 步骤 6 中的图像 3,3
    • Remove three 5 mm Phillips #000 screws located on the bracket.
    • Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed.
  7. Nikon Coolpix L810 LCD Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix L810 LCD Replacement: 步骤 7 中的图像 2,2
    • Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
结论
3等其他人完成本指南。
Emilio Mena
于01/14/15注册
752 声望
创作了4篇指南
团队
UW Tacoma, Team 3-1, Rose Winter 2015 UW Tacoma, Team 3-1, Rose Winter 2015 的会员
UWT-ROSE-W15S3G1
4 名成员
创作了8篇指南
2条评论
I love ifixit instructions so much more than youtube. These are so easy and straightfoward and I love how screw sizes are carefully specified.
Susan - 回复
Congratulations! Perfect lesson !
I need HELP presentation abowt desassembler / remove motherboard and other parts to repair the lenz move mechanism. Unfortunately NIKON left Brazil and the resident Suport tecnician besides not being good, stay in quarentine (corona virus)! Special Thanks for you help! Best regards
ramos.eng - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 2,612
