跳转到主内容
Nikon Coolpix L610 Power/Shutter Button Assembly Replacement
你所需要的
  1. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement, Plastic Cover: 步骤 1 中的图像 1,2 Nikon Coolpix L610 Power/Shutter Button Assembly Replacement, Plastic Cover: 步骤 1 中的图像 2,2
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: 步骤 4 中的图像 1,3 Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: 步骤 4 中的图像 2,3 Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: 步骤 4 中的图像 3,3
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement, Power/Shuttter Button Assembly: 步骤 5 中的图像 1,1
    • Remove the panel containing the power and shutter button.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 9-4, Brown Winter 2015 USF Tampa, Team 9-4, Brown Winter 2015 的会员
USFT-BROWN-W15S9G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 15
总计 739
