跳转到主内容
Nikon Coolpix L610 Camera Lens Replacement
你所需要的
  1. Nikon Coolpix L610 Camera Lens Replacement, Plastic Cover: 步骤 1 中的图像 1,2 Nikon Coolpix L610 Camera Lens Replacement, Plastic Cover: 步骤 1 中的图像 2,2
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Camera Lens Replacement: 步骤 2 中的图像 1,1
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Camera Lens Replacement: 步骤 3 中的图像 1,1
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Camera Lens Replacement: 步骤 4 中的图像 1,3 Nikon Coolpix L610 Camera Lens Replacement: 步骤 4 中的图像 2,3 Nikon Coolpix L610 Camera Lens Replacement: 步骤 4 中的图像 3,3
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Camera Lens Replacement, Control Panel: 步骤 5 中的图像 1,3 Nikon Coolpix L610 Camera Lens Replacement, Control Panel: 步骤 5 中的图像 2,3 Nikon Coolpix L610 Camera Lens Replacement, Control Panel: 步骤 5 中的图像 3,3
    • Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
    • Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
  6. Nikon Coolpix L610 Camera Lens Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the ribbon connecting the control panel to the camera. The latch can be removed by sliding it down and pulling the ribbon down.
  7. Nikon Coolpix L610 Camera Lens Replacement, Removing the screen: 步骤 7 中的图像 1,1
    • Using a prying tool, carefully lift up the LCD screen but do NOT pull it off.
  8. Nikon Coolpix L610 Camera Lens Replacement, Removing the LCD Screen Ribbon: 步骤 8 中的图像 1,2 Nikon Coolpix L610 Camera Lens Replacement, Removing the LCD Screen Ribbon: 步骤 8 中的图像 2,2
    • While the LCD screen is loose and unattached, there is a latch that is holding the ribbon in place. Slide the latch down and pull the ribbon out.
  9. Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: 步骤 9 中的图像 1,3 Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: 步骤 9 中的图像 2,3 Nikon Coolpix L610 Camera Lens Replacement, Camera Lens: 步骤 9 中的图像 3,3
    • Remove the 6 (3.70 mm) screws on the metal cover. Two of those screws are covered by black plastic covers.
    • After removing the screws the panel should come off and will look like the final image.
    • Be careful of the red and black wires on the top. If the flash is charged you could get a mild shock.
  10. Nikon Coolpix L610 Camera Lens Replacement: 步骤 10 中的图像 1,1
    • Unplug the two ribbons for the lens. There will be latch that will need to be slid down. After loosening the latch, the ribbon should be able to be easily pulled out.
  11. Nikon Coolpix L610 Camera Lens Replacement: 步骤 11 中的图像 1,2 Nikon Coolpix L610 Camera Lens Replacement: 步骤 11 中的图像 2,2
    • Remove the 3 (3.10 mm) screws that are located on the back of the lens cover.
  12. Nikon Coolpix L610 Camera Lens Replacement: 步骤 12 中的图像 1,3 Nikon Coolpix L610 Camera Lens Replacement: 步骤 12 中的图像 2,3 Nikon Coolpix L610 Camera Lens Replacement: 步骤 12 中的图像 3,3
    • There are two lens covers that will fall out after removing the back lens plate.
    • Remove the 6 (4.35 mm) screws surrounding the lens.
    • There are 2 more (3.70 mm) screws covered by a small black square located. Remove the black squares and proceed to unscrewing these final screws.
    • Remove the lens. It should just be free to pull it out.
结论
2等其他人完成本指南。
Jeremy
于01/21/15注册
1,027 声望
创作了5篇指南
团队
USF Tampa, Team 9-4, Brown Winter 2015 USF Tampa, Team 9-4, Brown Winter 2015 的会员
USFT-BROWN-W15S9G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 18
总计 2,343
