跳转到主内容
Nikon Coolpix L340 Memory Card Replacement
  1. Nikon Coolpix L340 Memory Card Replacement, Memory Card: 步骤 1 中的图像 1,2 Nikon Coolpix L340 Memory Card Replacement, Memory Card: 步骤 1 中的图像 2,2
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera.
    • If the camera lens is pointing towards you, there should be a small lever on the right hand side.
    • Take this lever and push it away from your body, while simultaneously pulling upwards.
  2. Nikon Coolpix L340 Memory Card Replacement: 步骤 2 中的图像 1,1
    • Gently press down on the memory card until you hear a click, then release the pressure to eject the card and slowly pull it upwards out of the slot.
结论
2等其他人完成本指南。
Kelly Kryzak
于04/12/16注册
140 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S3G3
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 24
总计 1,463
