跳转到主内容
Nikon Coolpix L340 Buttons Replacement
你所需要的
  1. Nikon Coolpix L340 Buttons Replacement, Buttons: 步骤 1 中的图像 1,1
    • Remove the 5 mm Phillips #000 screw located on the upper left side of the camera
    • Remove the 5 mm Phillips #000 screw located on the lower left side of the camera
  2. Nikon Coolpix L340 Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove the 5 mm Phillips #000 screw from the upper right side of the camera.
    • Remove the 5 mm Phillips #000 screw from the lower right side of the camera.
  3. Nikon Coolpix L340 Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove the 5 mm Phillips #000 screw from the bottom left of the camera.
    • Remove the 5 mm Phillips #000 screw from the left-center of the bottom of the camera.
    • Remove the 5 mm Phillips #000 screw from the center of the bottom of the camera.
  4. Nikon Coolpix L340 Buttons Replacement: 步骤 4 中的图像 1,1
    • Remove back cover of the camera.
  5. Nikon Coolpix L340 Buttons Replacement: 步骤 5 中的图像 1,1
    • Push buttons out of the back of the cover.
结论
Robert Estrella
于03/04/16注册
101 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S3G3
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 25
总计 1,325
