跳转到主内容
Nikon Coolpix L340 Battery Replacement
  1. Nikon Coolpix L340 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Nikon Coolpix L340 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera
    • If the camera lens its pointing towards you, there should be a small lever on the right hand side
    • Take this lever and push it away from your body, while simultaneously pulling upwards
  2. Nikon Coolpix L340 Battery Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L340 Battery Replacement: 步骤 2 中的图像 2,2
    • Once you have pulled up, four batteries will appear underneith
    • Note how there are two batteries facing upwards (circled in red)
    • and two batteries facing downwards (circled in orange)
    • When the new batteries are placed back in the camera, they should be put back in this same orientation
  3. Nikon Coolpix L340 Battery Replacement: 步骤 3 中的图像 1,1
    • Take out each of the batteries
  4. Nikon Coolpix L340 Battery Replacement: 步骤 4 中的图像 1,1
    • When all of the batteries have been removed you should see four places for four new batteries to be inserted
结论
2等其他人完成本指南。
Nikki Butts
于03/04/16注册
179 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S3G3
4 名成员
创作了8篇指南
4条评论
Hi, I just replaced my Nikon Coolpix L340's batteries with new AAs and have followed all steps correctly but my camera is still saying 'battery exhausted' when I try turning it back on. Any ideas why it's not working?
Thank you!
Mia - 回复
The negative terminal must be raised like the Duracell Ultra. The Energizer MAX and other AAs have a FLAT negative terminal. The manual warns against them.
thestevelink -
No lever, only recessed button
ccpotts47 - 回复
thestevelink - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 143
总计 9,496
