After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
Remove the back housing of the camera by lifting it directly up.
The back cover may be slightly tight, therefore more force may be needed to lift it up.
The display cable has a ZIF (zero insertion force) connector on the end. This has a tab that has to be pushed out before the cable can be safely removed.
Using a plastic opening tool or fingernail, pop up the black clip holding the display cable. This will release the cable.
Slide the display cable out of the connector.
The display cable can be damaged due to excessive bending, therefore avoid putting unnecessary strain on it.
The marked red box contains a highly charged capacitor. Check the charge using a voltmeter and discharge it first before continuing. Discharge capacitor guide.
Remove the screws holding the motherboard with a PH000 screw head.
