After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
Remove the back housing of the camera by lifting it directly up.
The back cover may be slightly tight, therefore more force may be needed to lift it up.
