跳转到主内容
Nikon Coolpix L330 Back Housing Replacement
你所需要的
  1. Nikon Coolpix L330 Back Housing Replacement, Back Housing: 步骤 1 中的图像 1,3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: 步骤 1 中的图像 2,3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: 步骤 1 中的图像 3,3
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 Back Housing Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L330 Back Housing Replacement: 步骤 2 中的图像 2,2
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
结论
Taibah
于02/09/16注册
121 声望
撰写一个指南
团队
USF Tampa, Team 2-10, Cagle Spring 2016 USF Tampa, Team 2-10, Cagle Spring 2016 的会员
USFT-CAGLE-S16S2G10
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 604
