跳转到主内容
Nikon Coolpix L320 LCD Replacement
你所需要的
  1. Nikon Coolpix L320 LCD Replacement, Batteries: 步骤 1 中的图像 1,2 Nikon Coolpix L320 LCD Replacement, Batteries: 步骤 1 中的图像 2,2
    • Flip the camera over to reveal the card/battery door.
    • Slide the button to the unlocked position and the door should pop open.
  2. Nikon Coolpix L320 LCD Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L320 LCD Replacement: 步骤 2 中的图像 2,2
    • Take out the old batteries.
    • Look at the yellow sticker inside of the the battery compartment. You'll see the symbol for the direction the new battery should face when replaced.
    • The “+” means to put the raised end facing up. The “-“ means to put the flat end up.
  3. Nikon Coolpix L320 LCD Replacement, LCD: 步骤 3 中的图像 1,3 Nikon Coolpix L320 LCD Replacement, LCD: 步骤 3 中的图像 2,3 Nikon Coolpix L320 LCD Replacement, LCD: 步骤 3 中的图像 3,3
    • Use a JIS screwdriver to remove seven screws from the frame of camera.
  4. Nikon Coolpix L320 LCD Replacement: 步骤 4 中的图像 1,1
    • Use an opening tool or spudger to separate the front and back of the camera.
  5. Nikon Coolpix L320 LCD Replacement: 步骤 5 中的图像 1,1
    • Use a JIS screwdriver to remove the screws connecting the LCD to the motherboard.
  6. Nikon Coolpix L320 LCD Replacement: 步骤 6 中的图像 1,1
    • Gently flip the LCD over to reveal a ribbon cable connected to the motherboard.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector. Then, you can safely pull the cable out.
    • Remove the LCD screen from the camera.
结论
MollyHenderson
于03/20/23注册
293 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-6, Ramos Spring 2023 UMass Dartmouth, Team 5-6, Ramos Spring 2023 的会员
UMASSD-RAMOS-S23S5G6
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 32
总计 159
