跳转到主内容
Nikon Coolpix L32 LCD Replacement
你所需要的
  1. Nikon Coolpix L32 LCD Replacement, Front Panel: 步骤 1 中的图像 1,3 Nikon Coolpix L32 LCD Replacement, Front Panel: 步骤 1 中的图像 2,3 Nikon Coolpix L32 LCD Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Remove the six(3.93mm screws) on the outside of the camera using a Phillips 00 screwdriver.
  2. Nikon Coolpix L32 LCD Replacement: 步骤 2 中的图像 1,1
    • Open the battery compartment door and pull the black back face apart from the front red face.
  3. Nikon Coolpix L32 LCD Replacement, LCD: 步骤 3 中的图像 1,1
    • Using the spudger, gently pull the LCD screen from the tray holding it.
    • Do not pull the LCD screen far from the camera because there is a ribbon cable connected to it.
  4. Nikon Coolpix L32 LCD Replacement: 步骤 4 中的图像 1,1
    • Use the spudger to lift up the small white retaining flap on the motherboard that is connected to the LCD screen's ribbon cable.
  5. Nikon Coolpix L32 LCD Replacement: 步骤 5 中的图像 1,1
    • With the small retaining white flap up, remove the LCD screen ribbon cable from the motherboard by sliding it out.
结论
另外一个人完成了本指南。
Sherika Jacobs
于09/15/16注册
348 声望
创作了3篇指南
团队
USF Tampa, Team 2-4, Blackwell Fall 2016 USF Tampa, Team 2-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S2G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 822
