跳转到主内容
Nikon Coolpix L27 Screen Replacement
你所需要的
  1. Nikon Coolpix L27 Screen Replacement, Screen: 步骤 1 中的图像 1,3 Nikon Coolpix L27 Screen Replacement, Screen: 步骤 1 中的图像 2,3 Nikon Coolpix L27 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Undo the latch at the bottom of the camera by pushing it to the side
    • Remove the batteries (and memory card if applicable)
  2. Nikon Coolpix L27 Screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L27 Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the two 5 mm Phillips #000 screws from the left side.
  3. Nikon Coolpix L27 Screen Replacement: 步骤 3 中的图像 1,3 Nikon Coolpix L27 Screen Replacement: 步骤 3 中的图像 2,3 Nikon Coolpix L27 Screen Replacement: 步骤 3 中的图像 3,3
    • Lift the cover labeled "A/V OUT" to expose a hidden screw.
    • Remove two 5 mm Phillips #000 screws from the bottom of the camera.
  4. Nikon Coolpix L27 Screen Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix L27 Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the two 5 mm Phillips #000 screws from the right side of the camera.
  5. Nikon Coolpix L27 Screen Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix L27 Screen Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix L27 Screen Replacement: 步骤 5 中的图像 3,3
    • Carefully pry the back cover starting from the battery latch.
    • Once all sides are loose, lift the back cover up and off.
  6. Nikon Coolpix L27 Screen Replacement: 步骤 6 中的图像 1,1
    • Carefully lift the LCD screen up towards the bottom of the camera.
    • The LCD is connected to a cable so don't pull it out yet.
  7. Nikon Coolpix L27 Screen Replacement: 步骤 7 中的图像 1,1
    • Lightly push back the white switch holding in the screen cable
  8. Nikon Coolpix L27 Screen Replacement: 步骤 8 中的图像 1,2 Nikon Coolpix L27 Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the cable from the camera.
    • Lift the screen out.
结论
Vishalpreet Sandhu
于01/18/22注册
157 声望
撰写一个指南
团队
2指南评论
would you know how to replace the little button battery just next to the screen, because the Lense is not retracting anymore?
Walter D. - 回复
where can i buy a screen replacement please
mo0nflwr - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 31
总计 1,062
