跳转到主内容
Nikon Coolpix L26 Camera LCD Screen Replacement
你所需要的
  1. Nikon Coolpix L26 Camera LCD Screen Replacement, Back Cover: 步骤 1 中的图像 1,3 Nikon Coolpix L26 Camera LCD Screen Replacement, Back Cover: 步骤 1 中的图像 2,3 Nikon Coolpix L26 Camera LCD Screen Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the batteries from the battery compartment by sliding the white battery compartment switch up and then move the panel toward the right.
  2. Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #000 screwdriver, unscrew the two 2mm screws next to the battery compartment on the right side of the camera.
  3. Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Unscrew the two 2mm screws on the opposite side.
  4. Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Flip over the rubber AV cover at the bottom of the camera. Unscrew the last two 2mm screws on the bottom of the camera.
  5. Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Using your hands, open the camera slightly by using the indentation above the camera compartment.
  6. Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Wedge the flat end of the spudger in between the front and back cover. Carefully push the spudger downward, which will lift the back cover off the camera.
  7. Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Gently pull the cover off the camera.
  8. Nikon Coolpix L26 Camera LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 1,3 Nikon Coolpix L26 Camera LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 2,3 Nikon Coolpix L26 Camera LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 3,3
    • Carefully flip over the LCD screen onto its front. Pull the top of the LCD screen toward you keeping the bottom of it inside the camera.
    • Do not pull on the LCD screen; there is a ribbon of circuitry that is connected to the motherboard.
  9. Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Gently hold the LCD screen down, so the ribbon lays flat against the back of the camera.
  10. Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Gently wedge the spudger underneath the white latch and lift the latch open.
  11. Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 11 中的图像 1,2 Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Use the flat side of the spudger to flip the white switch on the motherboard. You should hear a light click.
  12. Nikon Coolpix L26 Camera LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Gently pull the ribbon out of the switch.
结论
3等其他人完成本指南。
Sadie
于02/16/15注册
427 声望
创作了3篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 2,627
