跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
In this guide, we will give you step-by-step instructions on how to remove the logic board so that it can be replaced or repaired.
配件
没有特定配件。
  1. Remove the memory stick from the camera.
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver. There is one screw hidden under the AV cover that also needs to be removed.
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Pry the back cover from the left side of the camera. Remove the cover gently.
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Pry back the front cover of the camera starting from the right side.
    • Pry back the front cover of the camera starting from the right side.
  5. This is where energy for the flash is stored.  Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  6. Remove the tape on the right side of the LCD screen.
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  7. Lift the black latch connecting the LCD ribbon to the motherboard.
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
  8. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  9. Remove the 6 Phillips #00 screws anchoring the LCD base to the motherboard. Remove the LCD base plate.
    • Remove the 6 Phillips #00 screws anchoring the LCD base to the motherboard.
    • Remove the LCD base plate.
  10. Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the lens ribbon out.
  11. Desolder the connection of the motherboard to the lens ribbon using a soldering iron and desoldering wick.
    • Desolder the connection of the motherboard to the lens ribbon using a soldering iron and desoldering wick.
  12. Lift up the black and copper covering on the left side of the camera.
    • Lift up the black and copper covering on the left side of the camera.
  13. Pull the wiring at the top right of the camera away from the lens with tweezers.
    • Pull the wiring at the top right of the camera away from the lens with tweezers.
  14. Remove the cross-hair shaped wire cap to the left of the lens.
    • Remove the cross-hair shaped wire cap to the left of the lens.
  15. Remove the 3 screws holding the lens to the camera frame. Two 3.8mm black Phillips #00 screws on the sides of the lens.
    • Remove the 3 screws holding the lens to the camera frame.
    • Two 3.8mm black Phillips #00 screws on the sides of the lens.
    • One 4.6mm silver Phillips #00 screw on the bottom of the lens.
  16. There is a screw behind flash tube holding lens. Remove it, then gently pull the lens out. Be sure that the lens's ribbon clears the motherboard.
    • There is a screw behind flash tube holding lens. Remove it, then gently pull the lens out. Be sure that the lens's ribbon clears the motherboard.
  17. Remove the tape on the top of the logic board. Remove the tape on the top of the logic board.
    • Remove the tape on the top of the logic board.
  18. Remove the 4 Phillips #00 screws holding the top of the logic board onto the camera frame.
    • Remove the 4 Phillips #00 screws holding the top of the logic board onto the camera frame.
  19. Desolder the joint of the top and back of the logic board using a soldering iron and desoldering wick.
    • Desolder the joint of the top and back of the logic board using a soldering iron and desoldering wick.
    • You will need to have soldering equipment to complete this step.
  20. Move the top of the logic board to the side, exposing the top of the frame.
    • Move the top of the logic board to the side, exposing the top of the frame.
    • Desolder the two connections on the top right of the logic board using a soldering iron and desolering wick.
结论
3等其他人完成本指南。
Aaron
于2010年10月06日注册
272 信誉积分
撰写一个指南
团队
Cal Poly, Team 9-23, Regan Fall 2010 Cal Poly, Team 9-23, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G23
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 5
总计 3,301
