跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Nikon Coolpix L18 Lens Replacement
你所需要的
  1. Nikon Coolpix L18 Lens Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 Lens Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L18 Lens Replacement: 步骤 2 中的图像 2,2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 Lens Replacement: 步骤 3 中的图像 1,1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 Lens Replacement, LCD Screen: 步骤 4 中的图像 1,1
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 Lens Replacement: 步骤 5 中的图像 1,1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. Nikon Coolpix L18 Lens Replacement: 步骤 6 中的图像 1,1
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
  7. Nikon Coolpix L18 Lens Replacement, Front Cover: 步骤 7 中的图像 1,1
    • Pry back the front cover of the camera starting from the right side.
  8. Nikon Coolpix L18 Lens Replacement, Lens: 步骤 8 中的图像 1,2 Nikon Coolpix L18 Lens Replacement, Lens: 步骤 8 中的图像 2,2
    • Remove the 6 screws anchoring the LCD base to the logic board using the Phillips #00 screwdriver.
    • Remove the LCD base plate.
  9. Nikon Coolpix L18 Lens Replacement: 步骤 9 中的图像 1,1
    • Lift the black latch connecting the LCD ribbon to the logic board.
    • Gently pull the lens ribbon out.
  10. Nikon Coolpix L18 Lens Replacement: 步骤 10 中的图像 1,1
    • Desolder the connection of the logic board to the lens ribbon using a soldering iron and desoldering wick.
    • You will need to have the soldering equipment specified to complete this step.
  11. Nikon Coolpix L18 Lens Replacement: 步骤 11 中的图像 1,1
    • Lift up the black and copper covering on the left side of the camera.
  12. Nikon Coolpix L18 Lens Replacement: 步骤 12 中的图像 1,1
    • Pull the wiring at the top right of the camera away from the lens with tweezers.
  13. Nikon Coolpix L18 Lens Replacement: 步骤 13 中的图像 1,1
    • Remove the cross-hair shaped wire cap to the left of the lens.
  14. Nikon Coolpix L18 Lens Replacement: 步骤 14 中的图像 1,2 Nikon Coolpix L18 Lens Replacement: 步骤 14 中的图像 2,2
    • Remove the 3 screws holding the lens to the camera frame.
    • Two 3.8mm black Phillips #00 screws on the sides of the lens.
    • One 4.6mm silver Phillips #00 screw on the bottom of the lens.
  15. Nikon Coolpix L18 Lens Replacement: 步骤 15 中的图像 1,1
    • There is a screw behind flash tube holding lens. Remove it, then gently pull the lens out. Be sure that the lens's ribbon clears the logic board.
结论
5等其他人完成本指南。
Andrea Govea
于10/11/10注册
360 声望
创作了2篇指南
团队
Cal Poly, Team 9-23, Regan Fall 2010 Cal Poly, Team 9-23, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G23
4 名成员
创作了10篇指南
2条评论
Be careful. I got painful shock from the flash capacitor even though the camera had been turned off and the batteries removed. It is the red and black wires and green tube on the left side.
Discharge it through a resistor. Trying to short it with a screwdriver made ahuge spark and left a mark on the screwdriver.
sdalimon - 回复
Aconteceu-me o mesmo, agora não a consigo ligar.
O meu caro Sdalimon tem alguma sugestão?
Cumprimentos.
Alberto Lopes - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 29
总计 16,948
