简介
In this guide, we will give you step-by-step instructions on how to detach the lens from the logic board so that it can be replaced or repaired.
你所需要的
Remove the tape on the right side of the LCD screen.
Gently lift the LCD screen from its base.
Be very careful not to touch the flash capacitor on far left when lifting the LCD!! It WILL shock you.
Getting the LCD ribbon back "in" is my problem -- hints or suggestions?
I can't get a feel for how the black clip holds the ribbon - insert the new one at an angle?
I practiced a few times with the "bad screen" and managed to figure this out. Unfortunately I can't explain how I did it... if some other person can explain how to make the ribbon connection/clip re-install more predictable I think it'd help anyone else who tries the repair.
5等其他人完成本指南。
2条评论
Be careful. I got painful shock from the flash capacitor even though the camera had been turned off and the batteries removed. It is the red and black wires and green tube on the left side.
Discharge it through a resistor. Trying to short it with a screwdriver made ahuge spark and left a mark on the screwdriver.
Aconteceu-me o mesmo, agora não a consigo ligar.
O meu caro Sdalimon tem alguma sugestão?
Cumprimentos.
