跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Nikon Coolpix L18 LCD Screen Replacement
你所需要的
  1. Nikon Coolpix L18 LCD Screen Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 LCD Screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L18 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,1
    • CAUTION! This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of descent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the logic board.
  6. Nikon Coolpix L18 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Lift the black latch connecting the LCD ribbon to the logic board.
    • Gently pull the LCD ribbon out.
结论
8等其他人完成本指南。
Nonny
于10/11/10注册
219 声望
创作了2篇指南
团队
Cal Poly, Team 9-23, Regan Fall 2010 Cal Poly, Team 9-23, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G23
4 名成员
创作了10篇指南
4条评论
Good work! Appreciate it.
Oasis World - 回复
I need a new LCD screen replacement. A link to buy a new one?
William Pullman - 回复
Where can I get a replacement LCD screen for a Nikon L18 camera?
I found one for my Nikon Coolpix L18 on eBay.
Mark Fraylick -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 7,056
